Unplug tps andthe surging stops
Old Sep 3, 2007 | 04:11 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
I have a 89 l98 that surges 125 rpm or so at idle. Tuner Pro says my TPS is.57v, that's where I have it set. The voltage moves smoothly, no spikes or sticking, however when I disconnect it while the engine idles, the surging stops and the IAC stops changing 10 to 15 steps to correct whatever it's being told to correct.
Has my TPS failed?
GW
Old Sep 4, 2007 | 11:56 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Re: Unplug tps andthe surging stops
I guess it must not be a problem.
Old Sep 5, 2007 | 12:29 AM
Guest
Guest
Posts: n/a
The TPS is probably fine. You've thrown it into a limp mode by disconnecting that sensor. Being a MAF car (it is right?) it will run with the TPS disconnected and eventually somewhat normal. I'd check your minimum air setting and IAC and passages and clean the TB and plenum and see how it does then. 125rpm is borderline, depending on how it fluctuates. A scan tool will sometimes show the RPMs jumping around more than they are to some extent. If its annoying, then search more. If its tolerable, forget it.
Old Sep 6, 2007 | 04:09 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Thank you.
I did some more reading before you responded and the manual states the same thing. The problem is now much worse but I have posted another thread on it.
https://www.thirdgen.org/forums/tech...last-time.html
db057
Jan 10, 2020 08:55 PM
L98GTA87
Oct 19, 2015 10:43 PM
92camaro350cci
Oct 14, 2015 09:29 AM
earlpote
Sep 12, 2015 11:55 AM
