Will not start, no electricity either.
Old Sep 4, 2007 | 10:29 AM
broski's Avatar
last night i was leaving my girlfriends house. started up the car, no problems, then drove off, about 50 feet away, my car just killed. electricity dropped and engine seized.
from there no electricity was going to the car. no lights, nothing. when putting inthe key no sounds, no click, no lights, dead.
any idea what this could be? could it be a fuse?
Old Sep 4, 2007 | 10:43 AM
Re: Will not start, no electricity either.
Fusible link, at the starter.
They are pieces of relatively small wire that act as fuses to protect the large wires that feed battery into the car.
Look at the post on the starter where the pos batt cable hooks up; it'll be one of the smaller wires that also go to that post.
Old Sep 4, 2007 | 10:46 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by broski
...any idea what this could be? could it be a fuse?
Relax, it's unlikely the engine is siezed unless you have tried to turn it over manually and it won't.
Since the lights circuit is totally seperate from the ignition it's not a fuse.
Your problem is most likely battery cable or battery problem.
Check the stud on the starter where end of the battery cable is connected to the fuse links.
Old Sep 4, 2007 | 10:50 AM
broski's Avatar
well right now the car is sitting at a repair shop up the street. should i mention that to him?
how much do u think it will cost to fix?
Old Sep 4, 2007 | 11:17 AM
Engine: 350 4BBL
Depends on how much he knows about electricity and if he starts by pulling the dash out...
Orr89RocZ
Apr 25, 2016 08:28 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
cstrobel65
Aug 15, 2015 10:19 AM
mizz0313
Aug 12, 2015 06:45 AM
