No Check Engine Light
Old Sep 4, 2007 | 01:38 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
The check engine light will not come on in my car. Im looking through my service manual and it says one of the things to check is the 20amp battery fuse. Where is this fuse, in the fuse block?
Old Sep 4, 2007 | 04:28 PM
Re: No Check Engine Light
Logical place to start, would be to change out the bulb.
Old Mar 16, 2008 | 07:48 PM
kabal's Avatar
what would casue the engine light not to come on i have change the bulb several time and changed the connector for the bulb too it did not work need help what is this fuse this other guy was talking about theonly fuse i know if is under the dash by the steering wheel were the fuse box is is there another please advis thanks
Old Mar 16, 2008 | 10:57 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
need the same info bro!
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
