replacing "check engine" light bulb?
Car: 85 Camaro
Engine: 305 LG4
Transmission: TH700 R4
Axle/Gears: 3.08 drum
i have a 91 firebird that seems to have a burned out or unplugged engine light. are they easy to get to to replace? i need it to work in order to retake an emissions test. all of the other dash lights work, just not the check engine one.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: replacing "check engine" light bulb?
you need to take the guage pod out, you may have a cable driven speedo, so be careful when you do. the bulbs just twist out of the back side of the pod.
up noticed its a bird, you have an electric speedo, no cable.
