afr heads and headers
Old Sep 8, 2007 | 09:57 PM
ohyeahjay's Avatar
just picked up a pair of afr 195 eliminators straight plug heads and was wondering if anyone had them and the hedman long tubes. i run angle plug heads now and had to run the accell shorty plugs but now i am wondering if i will have problems.
Old Sep 9, 2007 | 06:30 AM
Pat Hall's Avatar
Re: afr heads and headers
From the posts I've read on here, the only time you run into problems is when you run the AFR angle plug heads with SLP 1-3/4" headers. The straight plug castings shouldn't give you any problems with the Hedmans. You should be able to run a standard length plug of your choice now that you'll be running straight plug castings, which is great for you since Accel ignition stuff is garbage.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
