starting and running problem
Old Sep 10, 2007 | 09:35 PM
dsw12387's Avatar
I have a 1971 Nova that i have done a TPI swap on.
I have got the thing to run but i am having a few problems, but the biggest one is that the engine will not start or stay running unless the throttle is wide open. after it starts running i can let off of it a little, but it will eventually die. I checked my TP sensor and it seems to be reading backwards. when the throttle is closed the computer is seeing WOT, when it is WOT it sees closed throttle. I am pretty sure this is the problem but i would like to see what some of you think it could also be if it doesn't fix it.
Old Sep 10, 2007 | 10:07 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: starting and running problem
deffinately get your TPS reading correctly before you do any other troubleshooting, if you dont all kinds of problems can occur. get a new TPS if it reads the same you may have to change your connector pinout.
Frozer!!!
Jan 19, 2024 04:55 PM
bryan623
Mar 22, 2021 06:43 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
