dead spot from 3-4k
Old Sep 11, 2007 | 07:35 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
dead spot from 3-4k
i changed out my motor a few months back all specs in sig...
it feels like its got some decent power but its being held back. its fine under part throttle but wot it shakes and feels like the engine is loading up from 3-4k as soon as it hits 4k it revs smooth again. any ideas on what to check?
Old Sep 22, 2007 | 09:34 PM
gapimpin's Avatar
Engine: 383 LT1
Re: dead spot from 3-4k
bump...
no one knows what i should check?
i was thinking maybe a carb problem vaccuum secondarys not opening till 4k maybe?
Old Sep 22, 2007 | 10:07 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i would bet carb... the shuddering seems like you might be lean. what is your timing like?
Old Sep 22, 2007 | 10:24 PM
gapimpin's Avatar
Engine: 383 LT1
really not sure.... i used all my old 305 stuff and the pointer on the 305 timing cover is in the wrong spot for the 350 balancer i used. the 305 pointer is at 12 o'clock and tdc on the 350 balancer is somewhere around 2-3 o'clock. i set timing by ear and sotp driving. i did verify its not the timing though... i changed it multiple times hooked the vacuum advance up to full and ported sources no matter what i did with timing i had the same problem from 3-4k. my brother in law was using a holly dp on his blazer until he could get his qjet rebuilt... he just got that done so i think im gonna ask him if i can borrow his carb to check it.
Old Sep 22, 2007 | 11:50 PM
Car: 91 RS
Engine: 350 vortec
the engine the balancer came off of has very little to do with timing tab location... the 6in balancer has the timing tab in one location and the 8in is in the other... either balancer will be fine on either 305/350...
it sounds like you have a lean spot when the secondaries are starting to open... but edelbrock... i have no idea how to correct that never understood all of the rods and hangers what nots
Old Sep 23, 2007 | 10:53 AM
gapimpin's Avatar
Engine: 383 LT1
my 305 balancer had a long sleeve on it with the timing mark. does that come off? maybe im looking at a groove that sleeve fits on or something?
RedLeader289
May 28, 2019 01:47 PM
LC2 TECH
Oct 13, 2015 11:53 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
raymondandretti
Sep 27, 2015 06:43 PM
