Twin turbos/desktop dyno...
Old Sep 22, 2007 | 03:42 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I've been trying to simulate twin turbos on desktop dyno 2000, but the program only allows for one turbo. What I've been doing is double the flow and pressure ratio ratings for a particular turbo and it seems to work, but is it correct?
Old Sep 22, 2007 | 04:01 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Twin turbos/desktop dyno...
Pressure ratio should stay constant, the flows should be doubled. That is Flow and Surge Flow. Efficiency should match the compressor map at the desired flow/pressure ratio.
Pressure ratio @ sea level is calculated by (Boost Pressure + Atmospheric Pressure)/ Atmospheric Pressure
Boost + 14.7
------------- = Pressure Ratio
14.7
Lets say that you are well above sea level and only have 13 psi of atmosphere.
Boost + 13
Old Sep 22, 2007 | 04:43 PM
bl85c's Avatar
Car: '85 maro
Duh! Pressure is a constant.
So why does power decrease when I increase flow and vice versa?? What am I missing?
Old Sep 23, 2007 | 03:14 PM
bl85c's Avatar
Car: '85 maro
Anyone?
ZZ3Astro
Aug 13, 2019 12:57 AM
bjpotter
Jan 22, 2019 12:27 PM
86Firebird86
Dec 26, 2015 07:21 AM
1992Z28!
Nov 19, 2015 07:33 AM
customblackbird
Oct 1, 2015 04:30 PM
