rough idle, 88 TPI
Old Sep 14, 2007 | 08:48 AM
maroman88's Avatar
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
rough idle, 88 TPI
my 88 TPI car idles very rough and usually stalls when in park or neutral, idles fine in drive. checked the fuel pressure and its good, cleaned the hell out of the IAC, i dont wanna spend $65 on a new IAC if thats not the problem, anyway to know if its working? what does it consist of inside? i cleaned out the whole throttle body also
the car only has one trouble code, 36, maf burnoff, its always had this code and had it before this problem.
all the vacuum lines have been checked
car has no smog and no charcoal canister, again had this problem before removal
Old Sep 14, 2007 | 10:10 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: rough idle, 88 TPI
I had put a new MAF in my car about two months ago and it started doing that samething the other day. When the SES light came on the other day i pulled the same code (36 burn off). I'm lucky because the MAF was covered and i got a new one free. I'm saying that is what your problem is but my car does run 110% again.
Old Sep 14, 2007 | 06:30 PM
maroman88's Avatar
im guna try cleaning the MAF wire, since the burnoff isnt workin maybe its all gunked up?
Old Sep 14, 2007 | 06:45 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Hey how do you read those codes your talking about? Do you have a code reader?
Old Sep 14, 2007 | 10:52 PM
maroman88's Avatar
yea i have a scanner, but u can pull them with a paper clip, check out chevythunder.com for details, its easy
jbd1969
Aug 17, 2015 07:06 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
