cam number help please
Old Sep 14, 2007 | 11:48 AM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I just tore down an l98 out of a 88 formula, and found that it already +30 hooray for me...
the cam however does not look stock, the number I got off of it are
773.CPC.BC13
Anyone know who made this or what the spec's might be.
ANY HELP WOULD BE GOOD...
Old Sep 14, 2007 | 12:03 PM
Re: cam number help please
GM
Just yerbasic weenie stock cam for your car
https://www.thirdgen.org/mods3 last one at the very bottom of the page
Old Sep 14, 2007 | 12:43 PM
gscz28's Avatar
Car: 89 iroc
thanks sofa:
with out changing anything else what cam can I go with??
Old Sep 14, 2007 | 01:25 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Well, it's already. 030" over, has there been any head work done? Are the valve springs stock? Etc?
You can go to an Xr264hr, or i'd recommend you upgrade the valve springs, and use the XR276HR, but you'd want a bigger stall speed to optimize it. Perhaps an S-10 convertor?
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
gixxer92
Sep 1, 2015 04:32 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
80s Poncho
Aug 19, 2015 06:45 PM
