Is this cam a upgrade? l69
Old Sep 15, 2007 | 11:18 PM
CrAlt's Avatar
Car: 83 TA
Engine: goodwrench 350
Performer-Plus 2102
RPM RANGE: 1500-5500
Duration at 0.006" Lift: Intake: 278° Exhaust: 288°
Duration at 0.050" Lift: Intake: 204° Exhaust: 214°
Lift at Cam: Intake: 0.280" Exhaust: 0.295"
Lift at Valve: Intake: 0.420" Exhaust: 0.442"
Timing at 0.050" lift: Open Close
Intake: 5° ATDC 29° ABDC
Exhaust: 44° BBDC 10° BTDC
Centerlines: Lobe Separation - 112° Intake Centerline - 107°
Is this cam much of an upgrade over the stock '83 cam or is it about the same?
I got this kit new in a box with a 2101 performer intake on a trade...
Old Sep 15, 2007 | 11:25 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Is this cam a upgrade? l69
Originally Posted by CrAlt
Performer-Plus 2102
I know some will dis-approve, but I have always liked the powerband of this cam in a 305. It will not make as much HP/TQ as some other more modern, hotter grinds, but it is easy on the valvetrain, runs silently, and has good driveablity. It will run on the 305 CCC Q-Jets stock ECM chip and carb settings. It will also run cleanly enough to pass the emissions test in any part of the country. I really enjoyed my 305 with this cam in it. Ported the 601 heads while I was at it and installed 1.94/1.60" valves into them.
Old Sep 15, 2007 | 11:35 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
if you already have it... run it... it will be an improvement later when you get bored with it you might look at one of the 262/268 cams from comp
Old Sep 16, 2007 | 02:12 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That cam won't make any noticeable gain over the L69 cam. Its pretty much the same. Only difference is a little more lift and a little smaller LSA. Not worth it.
If your L69 is healthy, put something in the 214-218* duration @ .050" and you'll start to notice a difference.
Old Sep 16, 2007 | 09:59 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That little tighter LSA is HUGE. Easy to make 25 ft/lbs more torque from 1,500-3,500 rpm. My 1983 G20 did have the same cam as the L69 in it. I put the Federal Mogul CS1014R into it. The difference in torque, throttle response, and HP was immediately apparent.
Old Sep 16, 2007 | 10:07 AM
CrAlt's Avatar
Car: 83 TA
ok thanks guys,
I have the new cam/lifter kit already. So wile im changing the timming set (engine is on stand) ill toss that sucker in there.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
