starts, revs freely in park, wont run
Old Sep 17, 2007 | 02:13 PM
okiejory's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
After days of searching this site ive decided to ask.
I have a 91 camaro rs 305tbi/700r4.
It started all of the sudden one day. The car starts just fine, revs freely in park, doesnt trip, sputter or anything. put it in drive and it goes for about 20 feet and just dies. stop, put it back in park, same thing. revs fine but dies in another 20 or so feet.
ive replaced the fuel filter, fuel pump, fuel pump relay, the entire tbi unit and followed every vacuum line looking for leaks, nothing.
then i tried spark plugs, plug wires, cap and rotor. same thing.
im loosing my mind here, so if anyone has a good idea it would be much appericiated.
Old Sep 17, 2007 | 02:36 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
Re: starts, revs freely in park, wont run
whats your car idling at when in park. I would mess with the idle first, if thats not the problem, you might have something wrong with the torque converter staying locked up
Old Sep 18, 2007 | 11:33 AM
okiejory's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
i thought the idle was factory set?
anyway a fairly camaro-savy friend of mine fingered the ecm as the problem, im going to replace that today and see what happens.
Old Sep 18, 2007 | 11:35 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
What engine/trans are we talking about here?
Old Sep 18, 2007 | 02:18 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
I had a similar problem with my ol' 305. I put a new alternator in cause I get the lifetime warranty ones. I took it in and said I wanted a new one, got it without a test of the old one. My car ran fine til I jumped back in it a week later, then same problem. That one test drive lead me to believe the alternator or wiring might be causing the problem.
Good luck, the bowtie gremlins don't like to leave
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sherpajames
Aug 7, 2015 06:56 PM
