$1200 Trickflow VS. 5¢ Machine Screw
Old Sep 17, 2007 | 04:36 PM
TeknoMaeg's Avatar
Yeah this blows... Some one sabotaged my friends engine and he claims the heads are a total loss... I bought them off him to make the guy feel less of a loss.
I have had two quotes so far... one said $250 to fix the chamber... the other said $500 for the chamber and full valve job...
I can't really afford either but if I can get the chamber fixed and both heads resurfaced I might be able to justify $300 max...
Any recommendations?
Maybe a way to fix it myself???
I can do port and polish but I have never tried to weld cast aluminum...
(yes I posted this in the regional as well) I just want more exposure for the recommendation on how to move forward...
Old Sep 17, 2007 | 05:14 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: $1200 Trickflow VS. 5¢ Machine Screw
You're lucky they're aluminum and not cast iron.
What's the mark at the left of the image between the two cylinders?
Old Sep 17, 2007 | 05:22 PM
TeknoMaeg's Avatar
No clue... just a light gouge...
I figure I can get a cast manifold and practice my welding on it... but I need to find any local solutions or maybe alternative solutions...
Old Sep 17, 2007 | 05:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd let the shop do it. You're going to need machine work afterwards anyway.
Old Sep 17, 2007 | 05:26 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
cast and aluminum welding are like night and day in comparison my friend. you can practice all day on a cast iron head or cast iron anything and it will never teach you how to weld aluminum..im not sure but i bleieve the only way to weld aluminum is TIG, i can TIG weld but not many people i know around here can
TeknoMaeg's Avatar
I got a guy that can do most of the machining that I can't do by hand... it's the welding I am worried about... to build the material back-up...
I know this... why do you think I said a cast intake? You really think I meant iron? Come now... use a bit of perception.
I have welded aluminum... You can mig it... I have never dealt with cast or having to weld for such crucial areas... If the weld cracks or chips... it means I am right back where I started.
Old Sep 17, 2007 | 05:30 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You can MIG it.. .But TIG is a lot cleaner.
Old Sep 17, 2007 | 05:31 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
thats true my bad. i have never mig welded aluminum before though.
Old Sep 17, 2007 | 05:33 PM
TeknoMaeg's Avatar
Originally Posted by Toehead
You can MIG it... But TIG is a lot cleaner.
In this regards, clean isn't needed. All I need to do is grind down what is damaged... add material with welding and then machine and grind it back to cast specs...
My main problem is the welding of the cast aluminum... Has any one have any experience with a MIG on cast?
Any tips or tricks over standard aluminum?
Old Sep 17, 2007 | 05:41 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
How To Successfully Weld Aluminum with a Compact MIG Welder
By Jim Harris®, Product Manager, The Lincoln Electric Company and Frank Armao, Group Leader, Non Ferrous Applications, The Lincoln Electric Company
When it comes to welding aluminum items around the home or garage, there are a few misconceptions we hope to clear up: 1) That you need to invest in a $4,000 welding machine and be highly skilled to have success; 2) With no practice you can make excellent welds the first time the wire feed welder is taken out of the box; and 3) You need an expensive spool gun suited for aluminum.
The truth is that with practice, the right equipment and proper set-up, a compact MIG welder will be able to tackle occasional aluminum welding jobs. Using your MIG welder, you will be able to work on a variety of items around your home and yard, such as grills, railings, backyard furniture, boat docks and even decorative elements. Compact MIG welders, such as the SP, Weld-Pak or Pro models from Lincoln Electric, are available at distributors and retail outlets.
A Word About Aluminum
Even home welding enthusiasts who have experience welding steel may find a switch to aluminum challenging. Here's why: Because of the softness of aluminum wire, it is more difficult to feed. In addition, wire diameters and machine settings normally used for steel may not be appropriate for aluminum. In order to be successful, ask yourself these questions:
What Machine Do I Need?
The first decision is what type of machine is right for the job. Keep in mind that a 115 volt wire feeder welder can handle jobs that range from 22 to 12 gauge and with moderate preheating, you can probably weld as thick as 1/8". Be aware that preheating should be limited to 250 degrees F maximum.
Another option is a 230 volt machine which can weld from 22 gauge all the way to 3/16". Proper preheat can take the range to 1/4". If you will need to weld a broader range of aluminum thicknesses, consider investing in the 230v machine.
Remember, if you plan on doing regular aluminum fabrication, you will need a heavy duty machine. The 115 volt and 230 volt compact MIG welder models are acceptable for occasional aluminum jobs, but not recommended for heavy duty aluminum use. For daily production welding on heavier aluminum, consider a welder that has greater than 200 amps output.
After you have chosen your input voltage, another common question you will be asked when selecting a welder is whether you want a continuous or tapped voltage control model.
A continuous voltage control model lets you set an infinite range of voltage within the rating of the machine, allowing more adjustability, fine tuning and precise control. This permits you to more easily adapt the voltage to your application and particular skill level.
If you're on a budget, opt for the tapped control unit. This machine has a rotary switch with four or five fixed voltage choices. It will not give you the control of a continuous model, but it can be slightly easier to get up to speed with and costs less to purchase and will be adequate for most applications.
What Type of Welds Can be Made?
For these types of machines, it is best to make welds in the horizontal and flat positions. In general, fillet welds in lap joints are made more easily than groove welds in butt joints. Fillet welds in tee joints are preferred over corner joints. Keep in mind that home welding by an amateur is not recommended for critical welds where failure could result in serious injury.
What Type of Shielding Gas is Required?
MIG welding aluminum is different than welding steel when it comes to shielding gas requirements. For aluminum, 100 percent argon is the gas of choice, whereas steel welding calls for a mixed gas or 100 percent CO2 gas. The good news is that no special equipment is needed - your existing regulators (with the exception of CO2 regulators) and gas hoses can be used for both pure blends and mixed gases.
What Polarity Setting is Needed?
All MIG welding, including on aluminum materials, requires electrode positive polarity, while flux-cored processes typically use electrode negative. If you are switching your wire feed welder between processes, make sure to switch your polarity. This is a common mistake that many beginning welders make.
What Aluminum Wire Electrode Alloy Type Should I Buy?
You will not obtain good results attempting to weld on aluminum with a steel wire electrode.
Instead, our recommendation is that compact MIG welders should be limited to .035" diameter 4043 aluminum alloy filler metal. A 5356 aluminum alloy electrode may commonly be recommended by retailers and distributors, since it is a stiffer wire and can be easier to feed. However, with these types of wire feed welders, there is often not enough amperage to achieve a good weld with 5356. Even though 4043 is a softer wire, following the proper steps outlined below will ensure good feedability.
Do not use other diameter wires. Specifically, you should avoid 0.030" wire (it is difficult to feed) and 3/64" wire (these compact machines do not typically produce enough current to reliably melt this diameter of wire).
How Do I Set-Up My Machine to Weld Aluminum?
Now that you know the type of machine you want and its capabilities/limitations, it is important to know how best to set it up. Follow these tips:
Purchase an Aluminum Feeding Kit
Attention to feeding issues is much more critical when it comes to aluminum welding. It is highly recommended that you purchase an aluminum feeding kit, which includes the following items:
  • Non-metallic liner - designed to minimize the amount of friction on the wire
  • U-shaped drive rolls - to avoid crushing or deforming the soft aluminum wire. These drive rolls do not shave the wire like V-groove drive rolls. Using V-groove drive rolls, the resulting wire shavings can clog the liner and lead to feeding problems.
  • Inlet and outlet guides - designed specifically to avoid wire shaving.
  • Contact tips - as compared to those used for the same diameter of steel wire electrode, contact tips for aluminum have larger diameter holes, since as aluminum heats up, it expands more than steel. Therefore, contact tips for aluminum applications are sized small enough to maintain good electrical contact, but large enough to allow for expansion.
Load Wire Into the Machine
There is a trick to properly loading aluminum wire into a wire feed welder. While the same technique should be used with steel wire electrodes, it is especially important with aluminum wire loading, to avoid feeding problems during welding.
With one hand, hold the wire spool securely so it doesn't unravel. Once you remove the cellophane wrapping, hold the loose end of the wire with the other hand - don't let go until you lock the wire into the drive roll.
Inexperienced operators commonly let go of the loose end and the spool starts to unravel. If this happens, it cannot be wound back up and still perform properly - you will have to purchase another spool.
Set the Wire Brake Tension
The idea is to have just enough tension to keep the wire from unraveling, but not too much tension so that it causes a drag on the wire. To do this, set the wire spool brake tension for a minimum setting. Then, load the spool on and feed it through the drive rolls. With everything stopped, if the spool keeps turning by itself, there is not enough brake tension. Be careful though, since too much brake tension can put excessive force on the wire.
And, operators shouldn't be surprised at the end of the spool if they cannot feed the last few turns; usually the wire is too stiff to come off easily.
Set the Drive Roll Tension
This step is probably the most important in the whole set-up process. The experts from Lincoln recommend holding the nozzle about 1" away from an electrically insulated surface at a slight angle. Then, set the drive roll tension close to minimum. Pull the trigger and watch the behavior - as the wire touches the insulated surface, the drive rolls should slip. Tighten down from that point until the wire stops slipping. Again, a word of caution, as wire that is set too tight will tend to 'birdnest'. This means the wire stops at the gun but the drive rolls are still turning. The result is wire feeds out of the drive rolls and birdnests, or backs up and tangles, anywhere along the drive path - at the guide tubes, in the gun liner, etc.
Remember, as you set the drive roll tension in the manner described above, that when the gun trigger is pressed, the wire is electrically hot, so always wear a quality pair of welding gloves.
Ensure Good Electrical Connections
The work clamp should be securely attached to the welding piece in an area free from paint and contaminants. To clean the piece, use a degreasing solvent to remove any oil and grease. Be sure that the surface is dry before you weld. Also, do not weld with flammable material nearby, such as a container of solvent or paint. As a second step, use a clean, stainless steel wire brush to remove all oxides from the surface of the aluminum.
Position Is Important
As you are welding, keep the gun cable as straight as possible to minimize feeding restrictions on the soft aluminum wire. A bend in the gun cable can make the wire kink and feed poorly.
Practice, Practice, Practice!
There is no substitute for practice. Just as a high-quality musical instrument won't make you a good player without practice, a welding operator needs to hone his or her skills as well. Before too long, you and your welder will be making beautiful music (or at least welds) together!
Old Sep 17, 2007 | 05:51 PM
Toehead's Avatar
Just watch the porosity!
Old Sep 17, 2007 | 06:22 PM
TeknoMaeg's Avatar
Definitely... going to use the same methods as regular aluminum... just preheat a bit and see how it goes...
3rd gen money
Oct 11, 2019 09:57 PM
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
