uh oh, no oil pressure!
Old Sep 18, 2007 | 05:32 PM
Shift06's Avatar
Car: 1991 Trans Am GTA
Engine: LSX (swapping)
Transmission: 4L60E (swapping)
Axle/Gears: 2.73 Posi 10 Bolt
Ok, I dunno whats going on, but when I start my car, the oil pressure is off the scale at 420 kPa or w/e. As it warms up it drops down. When fully warmed up, the car will have say 100 - 150 kPa while driving but when I stop at a light or something, it drops right down into the red and basically is touching 0. the car runs fine, ive actually been running it like this for awhile, i know im dumb yadda yadda yadda, but could it be a problem with my PCM or the oil pressure sender itself maybe?
Old Sep 18, 2007 | 06:22 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: uh oh, no oil pressure!
if all else is well it sounds like just the press. sensor . its the thing sticking out above the oil filter . be careful with the plastic plug going to the sensor . the plastic gets brittle with age . good luck .
Old Sep 18, 2007 | 09:31 PM
rhamm1320's Avatar
How 'tired' is your engine? Also, has this happened slowly over time or all of the sudden?
I have seen different brands of oil (same viscosity) run at different pressures in the same engine. You could go for the next higher viscosity if you have a high milage or high wear engine on the next oil change.
Old Sep 18, 2007 | 09:46 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
is it smoking? less power?
if not, probably just the sending unit or gauge.
MorrisL03's Avatar
Car: 91 Camaro RS
Axle/Gears: stock
I have a quick question about psi also. My stock 91 L03 with 10-30 conventional and a hot day idles at the line before 30...but scales with RPM. is this normal? I wasnt sure so i threw 20-50 in it to see if it helped and it really jacked up the PSI. People told me it was too thick for my mileage so i took it out and puttin 10-30 synthetic mix in it. (btw would about 2k miles with that thick oil kill my motor?)
**sorry for the hijack**
Old Sep 18, 2007 | 09:56 PM
TransAM Joe's Avatar
get a good mechanical hand held oil pressure gauge and it will tell you if it's the sensor or the bearing clearances are beyond help.
Old Sep 18, 2007 | 10:23 PM
Shift06's Avatar
I just rebuilt the engine, the crank was turned down like, .017 or .018. So, I had to put .010 over bearings in it, ..010 + .005 for oil clearance right? If i had put .020's in it wouldn't have worked period. The oil pressure was way up at 420 kPa ALL the time before the rebuild, so I am thinking it's just the sending unit... I wasn't sure if there was a way to test the unit other than using an oil pressure gauge, since I don't have one :P By the way I broke it in with thick oil then changed it back to 5w30, not much of a difference in readings between the change.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
