shift light coming on ? automatic trans, 1988 GTA digital dash 5.7 HELP
Car: 1988 GTA
Engine: 5.7 TPI
my shift light is coming on in my car, and it looks like the guage is getting stuck around 3k rpm. The transmission FEELS fine, its shifting gears fine from one to another, definately dosent feel like something wrong there. Is there a sensor that makes this shift light come on ? I have an automatic trans, whats the shift light for anyway when the trans shifts itself ? I have the 1988 GTA 5.7 with digital dash. Does this mean there is a problem somewhere, or do I need to replace some type of sensor ? HELP {PLEASE}
Chris
Chris
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: shift light coming on ? automatic trans, 1988 GTA digital dash 5.7 HELP
The shift light was never installed at the factory in automatic cars. If you put one in, it will light when the TCC locks.
Car: 1988 GTA
Engine: 5.7 TPI
This is the factory dash in my car, the DIGITAL dash for 1988. It has a shift light built in , in the corner near the tach. I have circled it in YELLOW in the photo.When it lights, it is a yellow arrow pointing up and says SHIFT..... I wondered what this area was , until it lit up recently while driving ! It only did it for a moment, while the car was cold... then quit. Noticed it again yesterday when I drove the car. The tach seems to get stuck around 3000 rpm ( yellow arrow ) and shift light comes on in the corner and stays on, even during tranny shifting from first to second..... It turns off for a second, then comes back on.. kind of like a short or something ?
I parked it until I can find out more..
ow and apeirion, what is a TCC ?
? I parked it until I can find out more..
Car: 1983 G20 Chevy
Transmission: 4L60
Car: Death Mobile
Engine: 666 c.i.
Aperion is right, the shift light does not work on an auto car. It is there to report problems with the engine. If it is coming on, the computer is telling you that you have a problem. You need to check the codes to see what is wrong. If you do not have a scan tool or code reader and do not know how to read the codes by shorting the pins in the ALDL port, go to this link
https://www.thirdgen.org/service-eng...ht-error-codes
Good luck.
Good luck.
Car: 1988 GTA
Engine: 5.7 TPI
OK.. thanks for that link, I will try.. but FIRST,
those instructions say
Run a wire/hairpin from Pin 6 to Pin 12 with the ignition off (although on later cars it should be from Pin 5 to Pin 6),
with my car being 1988 should I do 6 and 12, or 5 and 6 ?
also, Can I mess anything up by jumping the wrong pins ?
the location of this 12 pin DLC connector IS the one under my steering wheel , to the right ? correct ?
I have never noticed my check engine light even come on, but hopefully it does work and will flash some code when I try this.
Should I disconnect the battery and try to clear the codes FIRST ?
thanks
Chris
thanks
Chris
Car: Death Mobile
Engine: 666 c.i.
Follow the instructions, and if it doesn't work, try the other. DO NOT disconnect the battery until you have gotten all the codes. You should get three series of "12"s then your actual codes then "12"s again.
I actually don't do this to get the codes except in "jam" when I don't have my scan tool.
The_Phoenix
Feb 4, 2016 07:10 AM
beachrodder
Aug 7, 2015 04:27 PM
