Winage Tray for stroker
Old Jul 26, 2000 | 10:03 AM
freeze92's Avatar
I am building a 383, and would like to know if anyone has used a Milodon Diamond Stripper windage tray with a Scat crank? Summits catalog says that the tray will not fit 400's. Anyone know of a tray I could use?
Old Jul 26, 2000 | 10:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The tray doesn't fit 400 blocks, because the main bolts/studs are farther apart than a 350 block. It has nothing to do with the 400 crank. I don't know for sure if that crank will fit with that tray, it probably will, I suspect the rods would be a factor as well. That would strictly be a matter for trial and success.
Old Jul 26, 2000 | 11:00 AM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
The Moroso tray would not clear my rods on my 400 with ARP studs. There may be longer studs that you can buy to get it to clear but I tossed the tray and stayed with the ARP studs.
That was with a Scat crank and 6" rods.
[This message has been edited by Hurtin4Hp (edited July 26, 2000).]
Old Jul 26, 2000 | 12:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hurtin, I have GM studs in my 400 with the Moroso tray (the flat louvered Teflon coated one), and that all fits comfortably. You might want to look into that combo next time around. The ARP studs are much shorter than the GM ones. I did have to slot the holes in the tray though, per my previous post.
Old Jul 26, 2000 | 04:10 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey Huntin4HP, ARP sells a set of studs specially for the 400 and stroker application. You usually have to have a machine shop order them from ARP but, they do exist. BTW, I don't have a stroker YET but, I have the Moroso tray with longer studs in my 355. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Jul 26, 2000 | 05:19 PM
freeze92's Avatar
So it sounds like I'll just have to test fit the stuff huh? I'll see about ordering longer studs from Summit, and the tray also. They'll take anything back as long as you don't destroy it! Thanks for the help guys.
Old Jul 26, 2000 | 10:11 PM
Zee's Avatar
Zee
I have a 383 with a Summit pro line 4340 crank, Milodon diamond stripper windage tray and ARP main studs. All fits fine. The stock Z28 windage tray comes nowhere close to fitting.
Zee
[This message has been edited by Zee (edited July 26, 2000).]
Old Jul 27, 2000 | 08:33 AM
freeze92's Avatar
Just for info: I calles Milodon and talked with a tech. He told me that their tray will fit a 383 fine if you use their adjustable mounting bolt kit. I would rather buy the ARP bolts because they come as a complete set, not just the mounting bolts for the tray. Scat also claims that the tray will clear their crank, but did suggest turning the motor by hand to check for clearance. Thanks for the responses, and maybe this info will be some help for somebody.
Old Jul 27, 2000 | 09:49 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Milidon also sells a complete main bearing cap set for use with a windage tray. You can select either bolts or studs (which I have) for use with or without a windage tray. Both are rated at the same tensile strength and are made in the U.S.A.
George P. Lara
1984 Z28 High Output
Proud Member of SCFB
V6 T5 For Sale
Old Jul 27, 2000 | 02:55 PM
Hurtin4Hp's Avatar
Engine: 400 sbc
One other minor problem you might run into with the longer studs is them hitting the oil pan. I did install some longer studs to test fit the tray and found that when I put the oil pan on the studs hit. I was able to "dimple" the oil pan so the two that were hitting would clear, then said the heck with it and took them back out.
Old Sep 20, 2007 | 06:47 AM
Kurt04's Avatar
Re: Winage Tray for stroker
Yes, it did help someone, 7 years later.
But I have to ask if this it the one you guys are talking about.
http://store.summitracing.com/partde...rt=MIL%2D32250
The description says it doesn't fit strokers, but I find that a little odd. My block already has the longer studs, just not tray.
BDR
Nov 7, 2015 03:05 PM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
Chevykid810
Sep 28, 2015 12:57 PM
JSDaddy189
Sep 26, 2015 03:50 PM
