bent header flange makes backfire?
Old Sep 24, 2007 | 09:16 PM
Shred's Avatar
Car: 1986 Iroc-Z
Engine: 350cid crate
Transmission: t5- 5speed
Axle/Gears: stock
my passenger side header has a bent flange on it and makes the engine backfire. i guess this happens when air is mixed with heat and fuel supplied when the engine rpm is returning to idle(compression). Not only that but i can hear valve tick too, which wasn't there when there was no leak. So what would be the best way to repair this? i could probably try to flatten it and put a copper gasket on there instead of a standard one that tends to burn off.
my valves probably need relashing too hehe
Old Sep 24, 2007 | 11:18 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: bent header flange makes backfire?
I don't think that's the cause of the backfire. Relash your valves, and try to repair the flange, then go from there. Think you can just hammer it out?
Old Sep 25, 2007 | 10:35 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I'd be willing to bet that your exhaust leak is also causing the "ticking", and it most certainly can cause backfires. However, if you just recently adjusted the lash, that could be the cause as well.
Old Sep 27, 2007 | 03:20 AM
Pat Hall's Avatar
For your flange problem, I'd recommend using Percy's dead soft aluminum haeder gaskets. They're re-useable, and can seal fairly large irregularities. At the very least, you could use Mr. Gasket "Ultra-Seal" gaskets, and double them up. I wouldn't use the crap, white paper gaskets even on a perfectly straight header flange! I agree with jtrescot, the ticking could very well be the leaky flange instead of a valve.
Andrew6.688
Dec 13, 2015 10:59 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Cameeeero
Sep 18, 2015 04:00 PM
db057
Aug 22, 2015 08:17 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
