New engine, which plugs should I use?
Old Sep 25, 2007 | 10:33 AM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I'm wondering what would be a good start for plugs in a 355 10.5:1 engine with alum heads. I have a 50k Volt coil & 8mm wires. I was thinking around a delco 44T with .045" gap but I'm no expert in this field.
Old Sep 25, 2007 | 11:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: New engine, which plugs should I use?
I would check with Brodix for their recommendation. Note that many aluminum heads use a 5/8" hex, flat gasket, 3/4" reach plug. An example would be the Autolite 3924. Start with a .035 gap.
RBob.
Old Sep 25, 2007 | 11:50 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
OOPS! Missed the Brodix heads.
Not sure what style/reach plugs they use. My suggestion of NGK TR55's was based only on the proper heat range.
Old Sep 25, 2007 | 12:13 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
RBob.
I believe the 3924 is one of their reccommendations however I wasn't sure about what heat range and what size gap would be a good base line on a modified engine with larger coil.
Old Sep 27, 2007 | 03:15 AM
Pat Hall's Avatar
You usually don't have to start worrying about different heat ranges and gaps until you start using nitrous, forced induction, or turbocharging. Compression ratio can be a factor, but not really until you exceed about 11.5:1. I agree with Rbob, start with the standard gap/heat range, and go from there.
eightsixseven
Dec 16, 2024 01:50 PM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
