timing????
Old Sep 25, 2007 | 08:54 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
timing????
can anyone tell me what my timing should be for my 1986 trans am
it has a 305 tpi fuel injected 5.0 engine
i think its -6degrees but i need to know for sure.
Old Sep 25, 2007 | 09:36 PM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
Re: timing????
6 degrees while in drive
Old Sep 25, 2007 | 10:15 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: timing????
is the timing going to change when the car is in neutral...NO
well not if you are correctly trying to set the timing... dont bother with putting the car in drive... it is a waste of time.... and for those people with sketchy Ebrakes... lots of excitment
Old Sep 25, 2007 | 10:25 PM
Re: timing????
sry, i'm just following the directions that are on the hood of my car.......those must be wrong
Old Sep 25, 2007 | 10:45 PM
Car: 91 RS
Engine: 350 vortec
Re: timing????
why yes they are... how about i just write on that little sticker....smack your self in the head every time you set timing... would you do it?... now if you notice on the stick under the hood your YOUR car what does it say about cars manual transmissions? why would the automatics be different?
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
