v6 sping in a v8 car
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: v6 sping in a v8 car
Not much. I put V6 springs in my BBC car for a few years before finally buying trick springs for the front and a coil over shock system in the rear. The V6 spring may allow the car to settle a little lower.
Transmission: 4L80E/4L80E
Don't forget Stephen's was a race-only car.
I found that although the car didn't sit all that low, it would easily bottom the suspension in dips and over bumps. If you remove AC and PS in the process (or otherwise lighten the front end), you won't have as many problems.
V6 sway bars aren't as big as V8, either, so body sway will be worse.
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
thanks for the info .im just trying to get all my card lined up
BADNBLK
Northern Great Plains and Rocky Mountain
May 2, 2015 10:12 PM
steriko
Dec 27, 2005 08:58 PM
