Organized Drag Racing and Autocross Drag racing and autocross discussions and questions. Techniques, tips, suggestions, and "what will I run?" questions.
can my car get me to the 13's with this setup?
Old Dec 27, 2005 | 09:23 AM
steriko's Avatar
Car: 87 trans am
Engine: 357 ci chevy engine
Transmission: th350
CAR
87 trasn am
ENGINE
gm 357ci block (350ci 0.040 over bore)
gm 350ci crankshaft (0.010 over bore)
holley 750cfm
holley fuel regulator
holley red electric fuel pump
edelbrock torker 2 2500-6500rpm ported to match the heads (single plate)
gm's #128 aluminum 58cc fully ported heads
1.5 rocket roller
msd pro billet distributor
msd 6a
msd blaster 2 coil
accel 8mm spark plugs cable
accel u-grove headers spark plugs
federal mongul hypereutectics pistons
lt-1 stock rods
comp cams camshaft (duration int230 exh236 lift 487int 490exh 110lobe)
comp cams lifters
comp cams valve spings
comp cams push rods
merlin high v. oil pump
aluminum crank pulley
aluminum water pump pulley
cat aluminum water pump
proform gear drive
headmans long headers
3" catback
16inch electric fan
mini starter
TRANSMISSION
gm th350
hughers 2500 stall converter
trans. oil cooler
rebuild with tci stock pro kit
extra clutches
shift kit
REAL END
stock 10 bolts with 3.73 gears
SUSPENTION
stock
WEIGHT REDUCTIONS
no a/c system
no radio system
no p/s
no spare tire
no tools
can my car get me to the 13's with this setup? and how much power can i get with this?
Old Dec 27, 2005 | 10:59 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'd say yes, it should, but get rid of that intake, and get a Perf RPM or something... ditch the Torker II, you don't want it.
Old Dec 27, 2005 | 11:39 AM
Trevor86TA's Avatar
Car: 86 Trans Am
Engine: 406
Transmission: TH350, 4200
Axle/Gears: Moser 9", 3.89
The potential is there.
Tires will make a big difference though. What are you planning on using?
Old Dec 27, 2005 | 12:05 PM
89IrocZ350TPI's Avatar
Car: ws6
Engine: ls1
Transmission: m6
Id think you would be there no problem. Definitly get some slicks.
Old Dec 27, 2005 | 01:42 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
with a better intake(holley street dominator or edlebrock performer rpm) and assuming that the 750 holley is a double pumper and it's properly tuned, and you have sticky tires...i'd say low 13's, high 12's is possible
Old Dec 27, 2005 | 03:14 PM
steriko's Avatar
Car: 87 trans am
Transmission: th350
bf goodrich g-force t/a drag radial for the drag strip
and for the street a kumho brand
Old Dec 27, 2005 | 08:58 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
that should have no problem being 13's
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
onefreakz
May 14, 2018 12:15 PM
L98GTA87
Aug 11, 2015 06:55 PM
squiggy2
Aug 9, 2015 09:30 PM
