Running rich TPI
Old Sep 27, 2007 | 04:44 PM
quickbrad's Avatar
Car: 86 IROC
Engine: 355 TPI
Transmission: JUNK
Running rich TPI
Well I got the car running finally. It seems to be running pretty descent, but it is running really rich. It has new plugs, wires, cap, distributor, fuel pump, mass air flow, new pressure regulator, new injectors, fuel filter, air filters, and the timing is perfect. What would cause it to run rich? It is a 305 tpi. I run 93 octane in it.
Old Sep 27, 2007 | 07:09 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
Re: Running rich TPI
check o2 sensor
Old Sep 28, 2007 | 04:59 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
What did you set your fuel pressure at if it's an afpr?
What size injectors did you put in?
How rich is rich?
Need a bit more information to be of more help.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
