POPS and SPUTTERS
Old Sep 29, 2007 | 12:20 AM
ParkerTPIz's Avatar
POPS and SPUTTERS
1991 firebird formula
lo3 305 mx0 Auto trans
THIS THING BARELY RUNS-
it has a new fuel pump, fuel filter, new plugs, wires, cap and rotor....
It starts up easy, but when u give it gas it seems to hesitate, sputter and pop..and once i rev it up to around 2500 it will almost run right.....it will run in the mid RPMs or higher but at a start it almost dies(or it feels like its going to die)
COULD THIS BE A BAD CATALYTICAL CONVERTER? i looked at it, and it a complete pile of garbage....
ANY SUGGESTIONS? INPUT? ( KEEP IN MIND THAT IT HAS ALL BRAND NEW TUNE UP PARTS AND FUEL DELIVERY PARTS)
Old Sep 29, 2007 | 02:01 AM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Re: POPS and SPUTTERS
That doesn't mean anything, seen many a new part be junk. I'd start by checking fuel pressure. Have any trouble codes?
Old Sep 29, 2007 | 02:14 AM
ParkerTPIz's Avatar
i havent done the diagnostics test yet...but there are no lighrs popping up no SES light
COULD IT BE A RESTRICTED AIRFLOW (LIKE THE CLOGGED UP, RUSTED OUT CAT)
Old Oct 1, 2007 | 06:00 AM
Pat Hall's Avatar
Take off your air cleaner lid and check the spray pattern of the injectors while it's running. My L03 had similar problems a long time ago, and it was the o-rings around the two injectors. Instead of a fine spray or mist, the injectors were just dripping fuel. If you revved the motor up high enough, it would smooth out, but at lower rpms, it was just like when a carbed motor is running too rich and loading up. May not be your culprit, but it wouldn't hurt to check.
Old Oct 1, 2007 | 06:58 PM
ParkerTPIz's Avatar
TURNS OUT.......it was the COOLANT TEMP SENSOR......THE SES LIGHT STARTED TO COME ON, (it never had before,) SO WE RAN THE CODE. CODE 15...=CTS
it makes sense....it was getting flooded out, at a start, and then would run fine above like 2000 rpm.......
(it was acting like i was 40 below 0: just dumping fuel down it.)
NOW IT RUNS PERFECT!
THANKS FOR ALL THE HELP GUYS!
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
aaron7
Sep 30, 2015 09:15 AM
RS Reaper
Sep 27, 2015 07:04 PM
Lmancha96
Sep 25, 2015 08:11 PM
