melling oil pump spring color question
Old Sep 29, 2007 | 07:52 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
So I just replaced my oil pump (see this thread https://www.thirdgen.org/forums/tech...e-melling.html)
Noticed that the new pump has a purple relief spring and the old one had a yellow. Anyone know if theres a difference between melling relief springs?
Both pumps were ordered as standard volume standard pressure (new M55 and 10553)
Thanks.
Old Oct 1, 2007 | 12:21 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: melling oil pump spring color question
I *thought* the yellow one is the high pressure spring. I know I upgraded mine to make it a high pressure pump...
It doesn't show any color in this pic;
http://store.summitracing.com/partde...6&autoview=sku
But that's the high pressure spring.
Old Oct 1, 2007 | 03:13 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey 88305tpiT/A, just my two cents worth - I'm also running the Melling M55
slightly modified mind you. I swapped the "stock" spring that came with the pump out and replaced it with the "white stripe" spring. This spring is sometimes called the " Z28 " spring. I paid 4 bucks at the GM dealer for it.
It boosts the pumps output pressure to approx. 70 psi while your pump
volume remains "stock" which is what you really want out of your pump.
Hope I could help.
" The secret of life is honesty and fair dealing -
If you can fake that, you've got it made ! "
Groucho Marx
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
drathaar907
Aug 6, 2015 04:20 PM
