No power to Starter?
Old Sep 29, 2007 | 03:00 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
My car has been sitting without a tranny for about two years now and I have finally got everything in it and ready to crank, but when I turn the key nothing happens. It is as if the starter is not getting power. So I use a jumper switch on the solenoid and the car with crank. What does that mean? I tested the four wires that go to same post as the positive wire on the solenoid and they have power. I tested the purple wire that goes to other terminal and I got nothing. Should I have power at that purple wire? My solenoid cant be bad since it turns with the jumper wire right?
Old Sep 29, 2007 | 03:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: No power to Starter?
Check your clutch safety switch.
Old Sep 29, 2007 | 08:03 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Thanks for the input. I dont have one because this car was an auto. I ripped out the nuetral safety switch with all the auto wiring. Do you know what color it was? Also if you know what color the reverse light wire is I would appreciatte that.
Old Sep 29, 2007 | 08:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You'll need to put a clutch switch in then, and connect it to the neutral safety switch wiring.
Old Oct 1, 2007 | 12:46 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
The wires for the neutral saftey switch that you need to connect are a green wire with a white tracer and a solid purple wire. If you simply twist them togather the starter should turn, you really should wire in a clutch switch in for saftey though.
Old Oct 1, 2007 | 02:09 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Ok, thanks guys.
BRoss99
Aug 10, 2025 05:08 PM
5spdcamaro
Aug 28, 2015 02:12 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
