Oil pressure question
Old Sep 30, 2007 | 07:25 PM
83-84z28's Avatar
Car: 1983 z28
Engine: '73 4-bolt 350
Transmission: t5
Axle/Gears: 3.42 with auburn and 28 spline axle
when i recently put together my engine i noticed that the oil pressure sender took a dump on me, i verified gauge operation by appling ground to the lead and reading below 0 psi and disconnected got above 50 psi. I replaced the sender this weekend and when i turn the engineon it goes up to about 57-58 psi and goes clghly above 60 when accelerating it. Does this mean i have a high pressure pump or i have a possible restriction somewhere?
Old Sep 30, 2007 | 07:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: Oil pressure question
might be a bad sender or it's not making contact. Did you put a lot teflon tape on the threads?
Old Oct 4, 2007 | 10:21 PM
83-84z28's Avatar
Car: 1983 z28
Transmission: t5
sorry took so long to reply yes the old sender was bad and no i didn't put too much teflon on the threads just enough to seal. the new oe works just reads a bit high a wonder if its normal or what
btw i made sure to get the sender for 60 psi gauge and not 80 psi
Old Oct 5, 2007 | 08:03 AM
Zepher's Avatar
When my sender broke, I grabbed one from my garage and it did exaclty what yours is doing. I then went to the store and bought a new one and it worked great until last week. The friggin spade connector broke off, the same happened to the other one as well.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
