Horn help
Old Oct 1, 2007 | 08:39 AM
Tampa Hurricane's Avatar
Horn help
I know this is a stupid question, but the horn on my 92 Trans Am isn't working. I am trying to figure out what is wrong and from a quick look around can't locate the horn. Can someone give me a quick description of where the actual horn would be located?
Old Oct 1, 2007 | 07:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mine are inside the driver's side fender, just in front of the fenderwell.
Old Oct 2, 2007 | 07:54 AM
Re: Horn help
Thanks, I'll check there.
Old Mar 22, 2008 | 04:27 AM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
Re: Horn help
did you find your and your problem, i dont know where mines at, its not working and trying to find out why.
Old Mar 22, 2008 | 08:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Horn help
Like 57kid said, they're in the drivers side fender. On birds you'll have to pull the battery.
They're easy to diagnose. Usually the connector just gets corroded causing a bad contact. Power goes through the wire. The ground for the horn is it's mounting point to the car.
Jiggle the connectors. There are 2 horns. If you get nothing.....apply 12 volts right from the battery to the connector tabs on the horns. You could also just use a meter and check for voltage when the horn button is pressed but it can be difficult to do that without a second person. If that doesn't work you could check the ground but that's rarely the issue. Time for new horns.
There is a fuse to check.
There's also a stupid plastic plug in the steering wheel for the horns. All it is is a springloaded holder that i've actually found broken on my car.
Try that out.
Veaceonee
Sep 29, 2016 08:15 PM
Fox118
Sep 1, 2015 04:07 PM
tc7761
Aug 30, 2015 09:45 AM
Stauf
Aug 24, 2015 08:31 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
