enigine vibration? after trans install
Subscribe
Oct 3, 2007 | 01:35 PM
I just had a new transmission installed in my 305tbi camaro. the engine has developed a vibration after the install - but about a year ago i had this same vibration that went away after i went to an exhaust shop and the tightened my exhaust manifolds that seemed to fix the problem.
The vibration is back after a year and it happened at the same time as gettin my trans replaced, may be couincidence. I cant hear a exaust leak but I do hear 2 different ticking noises. one i believe is just the injectors ticking so no big deal there the other is i believe to be in the valve train. its not a slow tick either its a faster ticking at idol. when the rms get up to 1600-3000 range the vibration gets worse and the car seems to be slower, no real power.
im hoping its an exhaust leak from the manifold but i really dont know, im going to check that tonight, i did the timing last night and it was dead on. could a vaccum leak cause this or somthing with the transmission? anyone have some ideas to help me fix this t would be greatly appreaciated.
thanx.
Reply 0
Oct 5, 2007 | 11:53 AM
Re: enigine vibration? after trans install
so i may have an update, when the cars in drive i hold the brake and give it a little gas, at around 1250 rpm theres a metal on metal noise that coincides with the engine vibration, is it possible that the torque converter is out of balance or improperly installed?
Reply 0
Oct 5, 2007 | 12:01 PM
Did you inspect the transmission mount? It might be broken, common problem.
Reply 0
Subscribe
