Engine Ping?
Old Oct 3, 2007 | 05:20 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Engine Ping?
I have heard the term engine ping before. What exactly is it and what can cause it? Is it the same as engine knock?
When I start my engine, sometimes I can hear what sounds like a clicking or ticking noise when my windows are closed and radio off. Is this an engine ping?
Old Oct 3, 2007 | 07:07 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Engine Ping?
Engine ping always occurs when the engine is under load (going up a hill or accelerating are favorites, just before the transmission downshifts). It is caused by: Ignition timing too early, octane of gasoline below required, compression ratio of the engine too high for gasoline octane rating being used. It is best described as a "clink, clink, clinkity-clink" sound
as the engine is being accelerated or going up a hill. Also has been decsribed as a "herd of ping-pong ***** bouncing under the hood".
The TPI setup uses a "knock sensor" to detect when this happens and the ECM then retards the ignition timing to make it stop.
A ticking or clicking sound at idle are usually related to worn valve train parts or an engine with excessive wear.
Engine knock is a much louder, lower pitched sound. Imagine a baseball in a metal bucket and you are shaking the bucket violently from side to side. THIS is a good example.
Old Oct 3, 2007 | 09:12 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Engine Ping?
that does sound like detonation funny it is at idle like that... see the exhaust glowing...
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
