Idle/engine acting weird
Old Oct 3, 2007 | 07:49 PM
guptuck2002's Avatar
Car: 1988 Trans Am GTA
Engine: TPI 350
Hi,
I dont knwo if Ive posted or not here but I have been snooping the forums for a long time. I have an 88 Trnas am GTA 350 ofcourse. When I bought it from my cousin the exhaust was cut off after the cat so it was loud as hell. Ofcourse I loved it but I came across a borla exhaust for a low price and bought it. Normally I do all my own work but after other exhaust jobs I decided 90 bucks was a small price to pay for the full installation. So i gert it back and it sounds great. The firs thing I notice is a large drop in HP and tourque but this was not surprising considering the previous setup was almost strait pipes. So I started it up cold and I instantly noticed the engine was barely hangin on to idle speed. I give it some gas and it roars up and drops back down. I have to keep gas going for a good few minutes before it will idle freely. During these few the motor wants to bog when gas is added. Im very dissapoointed. Also, there is the dreaded engine check ligjht so many people have, that decides to turn on when it wants to. How do i clear the code without disconeecting the battery? No I dont knwo the code but I assume its the intake one because it was a few months ago. A side not is I installed a cold air filter after all the problems started with no noticeable results in preformance or idleing.
Sorry for the extensive list but I really want this problem reso=lved. i dont like seeing my baby suffer (;
Thanks alot for any help
Tucker
BTW it is a TPI.
Last edited by guptuck2002; Oct 3, 2007 at 07:50 PM. Reason: Automerged Doublepost
Old Oct 3, 2007 | 09:56 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: Idle/engine acting weird
whats the code #?
Old Oct 4, 2007 | 02:13 PM
Engine: TPI 350
Im trying to find out soon. before that though can anyone explain why putting on an exhaust might udeenly cause these problems?
Old Nov 5, 2007 | 02:54 AM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Sounds like your CAT is melted and cloged up.
Old Nov 5, 2007 | 05:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It shouldn't. Something happened to cause your problems.
Old May 5, 2010 | 06:49 PM
perry3's Avatar
Car: 87 z28 iroc-z
Engine: 350 w edelbrock carb and intake
Transmission: 700r4 auto
not sure if this is related but my 87 iroc has a crate 350 with an edelbrock 750 on it and its seems like maybe when it gets hot it does the same thing idle drops and when i go to take off the car jumps and sometimes dies. sounds like idleing problem but other than this it idles fine. any thoughts?
Fanatic1074
Oct 3, 2022 05:57 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
