cold engine squeal!!
Old Oct 4, 2007 | 04:50 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
when i start my car in the mornings or whenever its cold i get a reallllly loud and annoying squeal that sounds like a bad belt but its not i have two brand new belts on it and that never fixed it so is there anywhere i should check or has anyone had/fixed this problem?
Old Oct 4, 2007 | 05:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Take one belt off, start it up; if the squeal goes away, that was the belt and/or component that was causing it. If the squeal is still there, take the next belt off, start it up, etc.
Old Oct 5, 2007 | 08:04 AM
Brennan's Avatar
Re: cold engine squeal!!
thanks i suspect the power steering pump but we`ll see
Old Oct 5, 2007 | 08:13 AM
Stephen's Avatar
Car: 87 GTA
New belts, but are they tight? If they are too loose, they'll squeal, even brand new.
If the squealing stops after everything warms up, I bet heat expansion is tightening them, and making the rubber of the offending belt, have tighter grip.
Old Oct 5, 2007 | 08:32 AM
Brennan's Avatar
come to think of it that may be the problem because when my belts are off the alt. is a beeatch to turn by hand, ill check later and the belts are as tight as i could get them when they were new maybe theyll tighten more now that theyve been in use for a few days thanks for the help guys
Old Oct 5, 2007 | 09:06 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
If you can't turn the alternator pulley without a lot of effort, replace the alternator before it causes problems. I've not had much luck with rebuilt units so I just replaced a rebuilt unit with a sticky pulley with a new duralast gold one from Autozone. Gonna try and see if a new unit works out better than a 3rd rebuilt one.
All your pulleys should move relatively freely. Well, except the crankshaft pulley. If that moved freely you'd have a dead car on your hands...
The alternator pulley I just replaced was showing signs of dying other than the pulley being sticky/having a light scraping sound when turning it by hand. It was outputing a lil bit under specs unlike when it was "new". The new unit now keeps the gauge where it should be.
Also, if you have a smog/air pump, those pulleys tend to go too. My last one was making a godawful racket, but still worked. Once I replaced it... again... The engine bay was worlds quieter. I've found the noisest and least reliable pulleys/units on my car to be the alternator and the smog pump. On two different 1991 TAs I've replaced the alternator 5-6 times. The 1st time under the original factory warranty with maybe 25,000 miles on the car. The rebuilt smog pumps are a crap shoot. Original lasted 15 years, and I'm on my 3rd rebuilt unit in 3 years now. Easy to replace at least.
Old Oct 5, 2007 | 09:50 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
you can rebuild an alternator yourself for about 30 dollars.
Old Oct 5, 2007 | 10:55 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
mine did the same thing, if i had the lights on and the heater going there'd be too much draw on the alternator and the resistance would make the belt squeal until it was warm. now i just don't drive it when it's cold out :/
wasn't an option at the time tho.
Bryan F
Aug 18, 2015 02:28 PM
kyle5647
Aug 15, 2015 11:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
drathaar907
Aug 6, 2015 04:20 PM
