map sensor vac line?
Old Oct 6, 2007 | 07:11 AM
84noname's Avatar
ok i cant find the line that goes to my map. previous owner removed it as far as i can tell. where does it start from???on a 84 3o5?
Old Oct 6, 2007 | 09:53 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: map sensor vac line?
You have a MAP sensor? On an 84? I was not aware that they came with them.
Have a pic?
Old Oct 6, 2007 | 12:01 PM
Beast407's Avatar
The vacuum line to the map should originate from a nipple at the back of the carb baseplate adjacent to the vacuum brake booster tube.
Old Oct 7, 2007 | 12:52 AM
84noname's Avatar
thanks, yeah it has a map sensor near the passenger side mounted to a bracket next to the a/c canister
Old May 1, 2008 | 06:57 PM
CMan84Z28's Avatar
Car: 1984 Camaro z/28 HO
Engine: 305 HO
i actually have that same problem.
Old May 1, 2008 | 09:25 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
the map sensor on an 84 LG4 is located on the drivers side, on the fire wall, near the brake booster. As stated above it is fed by a line from a manifold vacuum source on the back of the carb. The sensor that looks just like it towards the passenger side is the "baro" sensor (barometric pressure). This sensor remains open to the atmosphere.
9192camaro
16
Feb 3, 2019 12:21 AM
IROCtometal
Sep 9, 2015 10:01 AM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
