Will start, and then won't start..
Old Oct 9, 2007 | 05:58 PM
veronica56's Avatar
1986 camaro 305
This car has been acting up for a while now. One second it will start and run great, the next it will run shabby and repeatedly stall. I recently installed a new carburetor in it but after that it would not start. So I put the old carburetor back in, but the problem is that it still will not start, ruling out a bad carburetor..
It has a new fuel pump and carburetor, and the ECM is okay and the distributor seems to get spark. So basically it cranks but just will not start. Any ideas?
Old Oct 9, 2007 | 06:52 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Will start, and then won't start..
Try some seafoam in the gas tank. do a search on this website about seafoam to get more info. and then change the fuel filter.
Old Oct 10, 2007 | 12:35 AM
Sonicbluecamaro's Avatar
Car: 84 camaro z28
Engine: 350 Carb
Transmission: Built 700 R4
Yea change the fuelfilter, get a clear one so u can see if theres any gunk going through, its only about 5$ at autozone or checkers.
Old Oct 10, 2007 | 01:39 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Possibly check timing.
Old Oct 15, 2007 | 02:16 PM
veronica56's Avatar
timing and gas filter are all okay...
Old Oct 16, 2007 | 06:46 AM
bigj350's Avatar
You may be getting moisture in the gas tank. Try some heet or stp, something that removes water. And if works but the problem keeps coming back change your gas cap. Also does your car have two filters. One inline and on in the carb.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Logan Bryant
Aug 27, 2015 11:52 AM
justin57
Aug 20, 2015 07:05 PM
EFR2000
Aug 18, 2015 08:54 PM
