Oil pan rails
Old Oct 10, 2007 | 07:47 PM
Cambridge205's Avatar
Car: 89 GTA
Engine: L98 350
Transmission: Swapped to a T-5
Oil pan rails
When I took off my oil pan I had 2 pieces that where in the shape of the oil pan rails and had holes for the bolts to go threw. What are they? And should I put them back on? Where they part of the old gasket? Because my new gasket doesn’t have them
Old Oct 10, 2007 | 07:58 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Oil pan rails
hmmmm, i know valve cover hade "load spreders" that went under the bolts, now if you had this on you oil pan it should match up with your factory holes.... if thats the case i would use it, but if its not like this.....maybe some pics would help, i have seen "load spredears" on oil pans before, but they match up with oil pan holes
Old Oct 11, 2007 | 03:51 AM
Car: 89 GTA
Engine: L98 350
Re: Oil pan rails
I remembered what they are for. They are for the bolts to spread the load. They go on the out side of the oil pan, and not on the inside like I thought for some reason... Thanks for the help!
Old Oct 13, 2007 | 12:54 AM
Pat Hall's Avatar
Re: Oil pan rails
All SBC's should have a set of those if you ask me. They work great for preventing the gasket from squishing out when the bolts are tightened too much.
Hotrodboba400
Dec 10, 2019 07:07 PM
Mdenz3
LSX and LTX Parts
Dec 10, 2015 11:18 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
