flywheel help
Old Oct 13, 2007 | 07:20 PM
z28gsxr's Avatar
Car: 91 RS Vert/98 Sierra9
Engine: 5.7/5.0
Transmission: 5spd/auto
Axle/Gears: 4th gen rear with 3.73
flywheel help
I looked under the car and i was able to pull a part number of 14088671 N GM1 off of my flywheel. I want to make sure that i have the right starter for this to avoid any problems. The starter i'm using is a powermaster High torque starter 9600. The starter says it is adjustable for both 168/153 tooth flywheels. Anybody have any idea how many teeth my flywheel has? Also does anyone know how to adjust the starter for either flywheel?Thanx
Old Oct 13, 2007 | 07:24 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: flywheel help
if you have the stock transmission you have a 153 tooth flywheel... i suppose it would be adjusted by swaping the drive gear...
Old Oct 13, 2007 | 07:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: flywheel help
most starters that ive seen that will work on both the 153 and 168 tooth flywheels, have 2 set of mounting holes. the closer set fo the small the wheel and further set for the larger wheel
Old Oct 13, 2007 | 08:24 PM
Nasty-Z's Avatar
Car: 1980 Z-28 /1992 S-10
Engine: 496 /421 Stroker
Transmission: 700R4 / Tremec
Axle/Gears: 4.88 / 4.30
Re: flywheel help
That is the was the 9600 is also , 2 sets of holes for 153/168 tooth flywheels/flexplates . it is also clockable for clearance issues .
TOM
Old Oct 13, 2007 | 09:40 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel help
thank you for the quick reply fellas I will bolt on the starter first thing tomorrow morning
Old Oct 14, 2007 | 11:30 PM
z28gsxr's Avatar
Engine: 5.7/5.0
Re: flywheel help
adjusted the starter and got the car started thanx for the help fellas. At the moment car is straight header. need to purchase a y pipe so i can mount the exhaust so i can finally drive the car.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
