How much longer will it live?
Old Oct 14, 2007 | 03:15 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
I have a .030 over 79 truck block 305 in my IROC and now its blowing smoke through the pcv and breather, and has started to miss. The motor only has 30K on the rebuild, but i let a friend borrow it and it was SEVERELY overheated to the point of where the upper radiator hose was almost split completely in half , i'm really surprised that the radiator tanks are still on it! My question is how much longer do you think it will live, according to the stock oil pressure gauge its still carrying decent pressure, its my daily driver, and i'm really short on cash, so if there is anything i can do to prolong its life i would like to do it. So what do you guys think? Will it run a while? Uncertain?
Old Oct 14, 2007 | 07:16 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
Re: How much longer will it live?
do a compression test on the motor see if you can find a weak cylinder... if you do find one try a leak down test if the compression doesent come back up its the head.
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ndndndnd
Sep 28, 2015 08:00 AM
