throttle cable swap to lt1
Old Oct 14, 2007 | 02:31 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
okay so i just swapped this BBK LT1 throttle body onto my l98 car and the cable is too short by about 1/4 inch.
i have the throttle cable bracket for an lt1 and as you can see in the first picture the bracket in my hand is the LT1 bracket. I noticed that on the lower portion of the l98 bracket theres an opening the exact same size as on the lt1 bracket. wondering if i can just put an lt1 throttle cable on the car through that opening?
my only other concern is that the lower hole would put the cable at a serious angle, im not sure if this would be an issue. anyone know why my bracket has that larger lower hole on the bottom?
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
timonator
Aug 13, 2015 11:27 PM
fonzie85
Aug 13, 2015 11:50 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
