Lock tite on bolt, have to remove....
Old Oct 15, 2007 | 06:44 AM
CamaroManBlack's Avatar
Car: 1984 Camaro
Engine: 2.8L V6 2BBL (yeah I know...)
Transmission: 700R4 automatic
I've got an engine with a crank pulley that I need to pull off. However, red lock tite was used on the big crank pulley bolt and won't bust loose with just hand tools.
I've been told that you need heat to get lock tite to let go. Can I use one of those disposeable MAPP Gas cylinders, or do you think it won't be hot enough?
Old Oct 15, 2007 | 07:28 AM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Lock tite on bolt, have to remove....
Whenever I find a bolt with locktite on it I just get a big reaker bar to gain more leverage and it breaks loose
Old Oct 15, 2007 | 09:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Yes, you need heat for red loctite. A simple propane torch is good enough, MAPP will DEFINITELY work.
Old Oct 15, 2007 | 06:34 PM
Car: 1984 Camaro
Thanks guys, I'll give it a try tonight
Old Oct 15, 2007 | 07:40 PM
Car: 1984 Camaro
It worked!!!
MAPP Gas is good stuff, all right!
Thanks again!
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Linson
Nov 12, 2015 08:09 PM
gixxer92
Sep 1, 2015 04:32 PM
