Fuel Lines?
Old Oct 15, 2007 | 03:14 PM
camarodreamer's Avatar
Fuel Lines?
Is this in the right section? If not, sorry.
Anyway, I am working on a 1989 Camaro RS and we went to start it and noticed gas spewing out of the driver side gas lines. Is there an easy way to fix it, or am I better off replacing it, or can I replace sections of it?
Thanks in advance.
Old Oct 15, 2007 | 03:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Fuel Lines?
is it coming out of the rubber lines that go to the motor or is it coming out the hard lines on the body?
either way you gotta replace it. its naturally easier to replace the rubber lines. you can upgrade to stainless line and AN fittings too if you'd like
Old Oct 15, 2007 | 03:39 PM
Re: Fuel Lines?
Well, to answer your question, it's coming out of the hard lines nearer to the engine itself. So, I will probably just replace it, just to be safe. Thanks!
Old Oct 15, 2007 | 04:40 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Re: Fuel Lines?
I had this same problem, a few weeks ago; and the easiest solution is to go to the junk yard and you might get lucky. There was a recall on the fuel lines in the early 90's, but again you can try tighten them for a temp. fix. I did that until I could find a replacment.
Old Oct 15, 2007 | 04:58 PM
Re: Fuel Lines?
Ya, that's what I'm gonna do. I'm gonna go to a salvage yard of some type and see what i can get. ( Christmas for me)
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
