Will this make 500hp?
Old Oct 15, 2007 | 08:37 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
I have a 11:1 406, etec 200 heads, super victor Jr. intake, HP750 carb. The cam is a comp cams extreme energy street solid roller, 242/248 @.050 .570/.576 lift on 110LSA along with matching valvetrain. Engine is balanced and uses arp hardware. Any guesses?
Old Oct 15, 2007 | 08:40 PM
Re: Will this make 500hp?
Given that all of the other supporting parts are up to the task (EXHAUST), probably so. At least once or twice. Maybe more, if you're a good short block builder.
Old Oct 15, 2007 | 09:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I had a short rod 383 with a cam having around .550" lift and it made around 500 hp on premium pump gas and 10:1 compression. Single plane intake with an 850 DP. Well worked over camel heads with big valves. Totally stock bottom end with factory cast pistons.
It was enough to push my car into the high 11's. I raced it for 2 years before throwing a rod and destroying the engine.
Old Oct 15, 2007 | 10:16 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Sounds good then. I just bought a no option 84 sport coupe I'm putting the 406/700R4 and 3500 converter. I'd like to see high 6's in the 1/8th for some bracket racing and some weekend street duty.
Old Oct 15, 2007 | 11:24 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Then ditch the 700R4 and install a TH350 or a TH400. You don't need an OD for the track or weekend street duty. It also has a poor gear spread from 1-2.
Old Oct 15, 2007 | 11:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
sounds like well over 500hp to me....
Old Oct 15, 2007 | 11:34 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It has everything you need to make 500HP. I would have tightened up the LSA to 106*, maybe 108*.
Old Oct 15, 2007 | 11:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
maybe more carb?
Old Oct 16, 2007 | 02:32 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
I've thought about it but there's a couple cruises in other towns I'd maybe like to take the car to.
I have a powerglide core in the shed, I've thought about using it but the car will probably weigh over 3K????? Maybe just get a higher stall to get the car moving?
maybe more carb?
The carb made 530hp with the 351W I have in my mustang with no signs of air or fuel problams. That being said I now use a 950HP on my mustang and the car does pull better everywhere.
Alot of the parts I'm using for the 406 are recycled parts(except for the heads and valvetrain) and actually it's been alot of fun putting the 406 together. Thanks for the responses guys.
Last edited by ditchbangr; Oct 16, 2007 at 02:37 PM. Reason: Automerged Doublepost
Old Oct 16, 2007 | 06:46 PM
AlkyIROC's Avatar
Car: 87 IROC L98
So? My race weight is just under 3100 pounds and I use a 1.76 powerglide. My converter stalls just under 6000 rpm. With a high HP engine, you don't need the extra torque multiplication of lower gears. My engine idles around 1000 rpm and pushing the throttle slightly will get the car moving. The best converter stall is determined after the engine has been put on a dyno.
Not all powerglides are the same. There were a lot of changes over the years. From a mix and match of parts, a good strong powerglide isn't hard to build. Stay away from the L6 1.82 geared ones. The gears are very weak. The V8 1.76 geared glides are better.
If you feel you "need" an OD tranny, use a 200-4R. Roughly the same gear ratios as the TH350 and has an OD.
Old Oct 16, 2007 | 08:21 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
what about one of those gear vendors kits for TH400/TH350's that give you extra 3 gears or something liek that?
Old Oct 19, 2007 | 04:02 PM
ditchbangr's Avatar
Car: One of 5
Engine: LB9
Stephen, one other question befoer I install the cam. When I called summit I was going to order their regular 330.00 CC solid roller lifters. The salesman made a suggestion to try a set of lunati's instead and save 50.00 at the same time. So I did as the couple times I've used lunati I've had good luck. When I opened the box the salesman sold me a set of horizontal link bar lifters with the springs. They are light and I guess their designed for cam swaps without removing the intake. I called lunati and he suggests the vertical but in my application they will be fine since I don't have alot of lift.
Do you have any experience with these?
Last edited by ditchbangr; Oct 19, 2007 at 04:04 PM. Reason: Automerged Doublepost
Hawk312
Aug 22, 2017 08:55 PM
ydnar417
Sep 23, 2015 05:57 AM
Drone358
Sep 1, 2015 02:50 PM
86White_T/A305
Aug 17, 2015 12:16 AM
z28addict8490
Aug 7, 2015 08:48 PM
