Fuel line/exhaust
Old Oct 16, 2007 | 01:21 AM
Slayre's Avatar
Fuel line/exhaust
I ran 1/2 braided line on the passenger side of the driveshaft tunnel almost same location as stock just on the other side. I did this because Im running a carb.Do you think heat from the exhaust will be an issue if I run single exhaust ? I want duels and more than likely I will dump them in front of the axle but if I go the single route will I have problems? I also thought about running the fuel line on the passenger side under the door, seems there is plenty of room for the most part, just getting by the LCA and then past the subframe up front. I have an external pump and filter mounted closer to the passenger side as well.
Old Oct 20, 2007 | 08:46 PM
Slayre's Avatar
Re: Fuel line/exhaust
Sorry guys, I think this got lost in the shuffle. Any input about this?
Old Oct 21, 2007 | 06:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
You will most likely not have any problems. But if you get real close to the fuel line with your exhaust, it couldn't hurt to throw up some heat shielding.
Old Oct 21, 2007 | 04:31 PM
Slayre's Avatar
Sounds good, the closest the fuel line gets is near the front subframe area turning up into the engine bay. I think there is going to be around 1"1/2 or so. I also have some rubber hydraulic lines from the tranny in that same area so I think heat shield, maybe even some wrap around the lines there couldnt hurt.
Old Oct 22, 2007 | 05:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Wrapping or shielding. The only downside to wrapping is it promotes corrosion of what you wrap due to moisture retention.
In my case (custom dual exhaust) I put up shielding towards the rear of the car. Up front I wrapped the exhaust (stainless piping) and put convoluted tubing on my shift cable. I kept melting the glue in my shift cable.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
