to stroke or not to stroke?
Old Oct 18, 2007 | 11:03 PM
TruStinger's Avatar
Just wondering what the advantages and disadvantages are to stroking out a 350 to 383? Would being supercharged matter? thanks
Old Oct 19, 2007 | 12:10 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: to stroke or not to stroke?
Supercharged doesn't matter, just pick the blower based on the cubic inches of the engine, not the fact that it's a "stroker" per se.
More cubic inches is the main advantage.
Disadvantages? If you have a good working 350 crank and pistons you need to shell out the coin for the crank, and stroker pistons. You will probably need to grind the block to fit the counterweights. It's just a new rotating assembly basically, same as if you bought a new 350 rotating assembly, you just have to clearance the block.
If you need pistons, and a regrind on the crank, you're pretty close to the same price as buying new 383 specific parts. That's the point in your engines life where it's CHEAPEST and EASIEST to get that 33 cubes, and the HP associated with it. When it's all buttoned up the HP costs more. Get it while it's cheap
junior419
Apr 7, 2025 11:35 AM
randy210
Oct 15, 2015 03:43 PM
dusterbd
Sep 29, 2015 08:40 AM
C409
Sep 23, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
