vats system help
Old Oct 18, 2007 | 11:12 PM
wisconsintta's Avatar
vats system help
my car has a problem that no one has ever seen happen my vats system is going crazy most of the time after sitting over night the car will not start on the first try ...you have to wait 4 min for the vats system to do something ?then it will start if you turn the car off in 1 min 3 min 20 min it dont matter it will not start but if you wait 4 min it will most of the time if it has a miss fire or dont catch on the first try you must wait another 4 min ....most vat system info i read tells me that the security light should stay on if the system has failed also it shouldnt let the starter turn over neather is my prob. i had a lock smith check the key and the reader of the code ...all is good ....my guess is that its the vats box itsself but i cant find it anywere i need help asapany help pleasePaul
Old Oct 19, 2007 | 12:28 AM
Pat Hall's Avatar
Re: vats system help
Yeah it does sound like there's a problem with the VATS box. The delay timer sounds like it's malfunctioning. According to the factory service manual, the decoder box is located behind the LH side of the instrument panel, near the steering column. Unless you're worried about keeping the VATS system functional, I'd highly recommend bypassing it. Go to www.tpiparts.net. They sell a VATS bypass module for $40. It's located in the electronics section of the online catalog. I despise the VATS system because the only thing it seems to be good for most of the time is disabling the actual owner of the car from being able to drive anywhere.
Old Oct 19, 2007 | 09:23 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I suggest disabling it as well, it's a PITA and the only thing that has left me stranded.
If the key/tumbler is bad then just measure the resistance of the key and jumper the two yellow wires under the dash with resistors of the same value.
Old Oct 19, 2007 | 10:25 AM
sykotik's Avatar
This post has helped me tremendously. I was posting about the '91 Firebird, and this is the ultimate in posts in my opinion.
That bypass will get the V6 up and running and I'll have a vehicle with which I can start to once again conduct business as usual.
Thanks to you all!
Old Oct 19, 2007 | 12:21 PM
The key and lock tumbler are in good working order as I have them checked by a lock smith. I ordered the vats bypass I will post up then I receive it and have it installed. Thanks again for the help
Old Oct 23, 2007 | 05:31 PM
I installed the vats-030 bypass module. it did not solve the problem. Then someone told me that the ignition module could be bad. So I changed it and still have the same problem. Any other suggestions
Old Oct 23, 2007 | 07:40 PM
89RJcamaroRS's Avatar
Car: 1989 camaro RS
Engine: RAMJET 350
Transmission: RAPTOR 700-R4
neutral safety switch. or clutch safety if a manual
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Winchester1094
Sep 15, 2015 09:48 AM
383cam
Sep 9, 2015 06:01 AM
studebaker60
Sep 7, 2015 12:36 PM
