How to set timing on a TPI Maf Camaro (Timing Problems)
Old Oct 19, 2007 | 05:18 PM
ChampionN84's Avatar
Car: 91 Camaro Z28
My car back fires through the TB when i give it gas and it runs like crap! I have a TDC tools but when i screw it in and make sure it is on the compression side the timing mark is way off! Since it is stock what should i do?
Old Oct 19, 2007 | 06:16 PM
Guest
Guest
Posts: n/a
Re: How to set timing on a TPI Maf Camaro (Timing Problems)
Who if anyone set the spark timing? In order to do that you need a timing light, and disconnect the tan wire thats near the AC to disable the ECM's spark advance.
Old Oct 20, 2007 | 09:58 AM
Car: 91 Camaro Z28
i meant how to i get it on top dead center!
Old Oct 20, 2007 | 12:12 PM
Guest
Guest
Posts: n/a
Might be the balancer has slipped. Where's your timing mark? It should be at about 2 o'clock, looking at the front of the engine. I've seen cars with the wrong timing covers swapped in before. You are trying to find TDC from the front driver side cylinder right?
If you have something to positively identify TDC, do that and mark zero on your balancer with chalk and use that to set the timing. If the balancer slipped... might be time for a new one.
Old Oct 20, 2007 | 01:29 PM
Car: 91 Camaro Z28
well the balancer and engine are stock never touched. Did you ever use a top dead center tool? it seems after you take it out that you can go up some more. so that wouldn't be top dead center would it?
Old Oct 21, 2007 | 12:02 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The tool locates dead center by stopping the piston before it reaches the top , turning the crank in the opposite direction stops it the same distance from the top, half way between the 2 stopping points on the balancer is DTC.
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
