Car randomly dieing while moving
Old Oct 22, 2007 | 06:59 AM
livewire195's Avatar
Just got back from the military, and the car has not been touched for about five months besides my dad doing some minor work like shocks, springs, brakes, trans tune up, and a fuel filter. I was coming back from my unit about sixty miles away, on the parkway. I was going about 70 MPH, and the check engine light came on and just the car died on me. (Needless to say I was scared shitless, it had to die on a turn; no power steering or brakes!) Now I changed the oil, and it seems to be running better. But it will still randomly die, and when it dies, like me turning the key off. However after waiting a while it will start up. When it first died, all the gauges were fine, tempature, fourteen volts, has gas, and the oil pressure was good. The only thing I noticed now is when I put the car in reverse, it stutters and sound like its going to die.
Please help! I deliver pizza and need my car back!
Thanks in advance,
PFC Briffa.
Update:
I looked around on the forums, and decided to check the fuse box. I discovered that the fuse labeled " ACR " was blown. Now it seems to run fine, but when I reverse the engine starts to stutter. Any Ideas? What does the fuse " ACR " stand for?
Old Oct 22, 2007 | 09:31 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
Re: Car randomly dieing while moving
Typically that refers to accessories, which is unrelated to your problem. You're certain it won't die randomly now? That would have sounded like an intermittent short in a critical system, so let us know if it happens more.
As for the stuttering problem, I don't know off the top of my head. Do you not get the same stutter when you put it in drive? This should represent the same load on the motor, so a different result points to something else as the culprit.
Old Oct 22, 2007 | 10:12 PM
LORDCRETH's Avatar
Car: 1998 Corvette Conv.
Engine: 5.7l
Transmission: 6-speed
Try changing your fuel filter. If it is partially clogged, it will run for a while until it starts to starve, and then will die.
Old Oct 23, 2007 | 09:22 AM
The car seems to run fine in drive, it only will die in Reverse. Sutters, check engine light illuminates, and then it dies. I'm so lost... lol
Old Oct 23, 2007 | 12:58 PM
thegooseman's Avatar
Car: 1992 RS
Wow I have the exact same problem. It happens usually when I have the ac on but not always. My car has also died out sometimes when I throw it into reverse. But this is not a everyday thing and I do have error code 32 that pops up. So to recap, it happens to me the most is when the a/c is on, I have been driving a while (at least 30 miles), and sometimes in reverse. So when you find out what it is let me know cause it really sucks when it dies. (especially on the freeway)
Old Oct 23, 2007 | 01:11 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
Not sure about the reverse part....but back in April my car would do the exact same thing, it would do one of two things.... 1) Die while moving at random, or 2) start to chug/engine light come on and then die.....
Turned out to be a bad wire going to my coil, after it was fixed...no more of that...
Old Oct 23, 2007 | 02:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That would be my guess.
Ghettobird52
Jul 5, 2024 11:18 PM
TheExaminer
Aug 26, 2015 04:59 PM
AkDrifted
Aug 17, 2015 07:45 PM
fonzie85
Aug 13, 2015 11:50 AM
