Question about IAC Adjustment
Old Oct 22, 2007 | 02:10 PM
RookieTuner's Avatar
Car: '89 Formula
Axle/Gears: G92
My car idles like crap and some times just dies so I thought it could be the IAC. I did exactly what the Tech article says to do. But when ever I start the car to adjust 'minumin air' the IAC makes a loud buzzing sound. I this normal or am I doing something wrong? Or does it mean that my IAC is broken?
Old Oct 24, 2007 | 12:11 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Question about IAC Adjustment
I've never heard an IAC make any buzzing sound... so my guess is its malfunctioning.
Hope this helps.
Old Oct 24, 2007 | 03:32 PM
Car: '89 Formula
Axle/Gears: G92
Has anyone ever adjusted ther min. air the way the tech artical says?
Old Oct 25, 2007 | 07:47 AM
rhuarc31's Avatar
Car: 89 Formula 350
Engine: 409 nitrous' small block
Sure. I've had the IAC make a noise that could be interpreted as buzzing when the ALDL was grounded and the ignition turned on. Thats normal, wait a bit for it to move all the way then unplug it. Shouldn't be able to make noise then. Then start the car and set minimum air to spec - around 450 rpm for stock cars, higher if you've modifyed it. Once you get that set then shut the car off and plug the IAC back in. Restart and you should be all set. If it's buzzing loud enough to hear over a running motor, you probably have an issue with it.
specialized
Jun 18, 2022 09:26 AM
86IROC112
Aug 21, 2015 07:20 PM
86IROC112
Aug 21, 2015 12:39 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
