what are some of the symptoms of bad sending unit
Car: 1987 IROC Z
Engine: 5.7
I was curiuos what the symptoms of a bad sending unit would be ? would it cause the pump not to work or go bad? I installed a new pump a year ago and everything worked fine guages fuel pressure ran nice. I have been restoring the car so it d has not left my garage in a couple years. I took the intake and phenum off to powder coat. When I put it back together hit the key heard the fuel pump relay kick in . but no fuel prime or pump running noise like before. and the fuel guage goes way beyond full when the key is on, when off it will drop a little below full. I am baffled at this. everything except the sending unit is new on this car. what have I possibly done?
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: what are some of the symptoms of bad sending unit
Sounds like the wiring harness that goes to the tank, isn't plugged in.
See my signature for helpful troubleshooting advice.
Ghettobird52
Jul 5, 2024 11:18 PM
ambainb
Apr 25, 2016 09:21 PM
Glowsock
Aug 26, 2015 12:28 AM
