wrong EST?
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
wrong EST?
I have 2 different EST laying around. One from and 88 z28 and the other from 92 Z28. The part numbers are different and the parts stores show the 88Z not interchangeable with the 92Z. Are they different or is this just number thing.
Engine: 400 and 350
Wrong ICM?
I have two ICM and one from a 88 Z28 and the other from 92Z28. Are the two ICM different or is it just the numbers listing. I have the 88 ICM in my 92 and the car just seems like its lacking power but not sure if the ICM is why.
Transmission: 4L80E/4L80E
From what I understand:
'88 is MAF, '92 SD. Shouldn't affect the ignition module.
'88 has separate knock sensor module, '92 has it built into the ECM. You said "EST", that's usually what the knock sensor module is also called - so there shouldn't be one for a '92.
I answered the "EST" thread first, then found your ICM post.
Are these two different questions, or were you correcting yourself?
Engine: 400 and 350
Re: wrong EST?
Anyone? Accel list a different part number for 91 and 92 and so does GM but not the part store.
