Exhaust manifold heat shield (stoopid...)
Old Oct 31, 2007 | 12:31 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Does anyone have a picture of an L98 passenger exhaust manifold with the heat shield installed? I stupidly took it apart figuring it was no big deal. Now the only way it seems to fit seems to also be wrong. I assume the spark plugs should be under the shield, not over it?
Sorry for a seemingly stupid question, but there's not a lot of room in there to experiment.
Old Oct 31, 2007 | 12:48 PM
Re: Exhaust manifold heat shield (stoopid...)
The heat shield goes above the plugs and below the manifold. It's held on by 2 little screws into the side of the block right below the head gasket. It's pretty much a no-brainer (which explains why I can understand it....), it only goes one way.
Old Oct 31, 2007 | 01:07 PM
jv9999's Avatar
Engine: 5.7L/350
Hey, I said it was stupid. :-) On my '87 it mounts under the exhaust manifold studs. The only way it seems to fit has a piece that sheilds the A/C box which seems right, but it's under the plugs and blocks the knock sensor.
Dyno Don
Jan 24, 2016 08:24 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
mustangman65_79
Sep 1, 2015 03:51 PM
kyle5647
Aug 15, 2015 11:56 PM
