can an exhaust cutout mess with the computer?
Old Oct 31, 2007 | 02:26 PM
ccook-92-305's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R4 w/transgo 700 shift kit
Axle/Gears: 3.42 posi
I put an exhaust cutout on my 92 camaro. Ive got flowtech shorty headers and no cat. The cutout is under the passenger right about where the old cat used to be. I took it to an 1/8th mile dragstrip and ran a 10.184 with the cutout closed and when I opened it I ran a 9.878 but only the first time. Every run after that was around 10.1 and when i closed the cutout after about 5 more runs the car wouldnt run. I started it 3 times and 3 times it died. On the 4th try i put my foot in it a little and it ran but very roughly, i got it moving and once it came up a little in the RPM's it smoothed out and ran exactly like it used to. Did the computer change things? or do I maybe have a different problem that jus happend to come up at that time. If it was the computer is this bad? Should I not mess with the cutout any more? Im just not exactly sure what could of happend, sorry for the long explination, but anything anybody's got is more than i know. Thanks much.
Old Nov 2, 2007 | 10:46 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: can an exhaust cutout mess with the computer?
I'm a little out of my league here, but this is my 2 cents...
On my car, my timing changed after I hooked up my Y-pipe to my exhaust.
So I would check your timing with the cutout open & closed. The computer may be re-adjusting the timing.
Again, just my 2 cents but might be worth a try.
Hope this helps!
Old Nov 2, 2007 | 11:22 PM
cooter26's Avatar
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
do you have an o2 sensor in your headers?
Old Nov 4, 2007 | 04:15 AM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
an O2 sensor too close to the cutout could be reading false content by having outside air present in the area. the O2 will read fresh oxygen and compensate for it by adding extra fuel when its not need and cause an overly rich condition. i know when i was running open headers with my O2 sensor 6 inches from the collector my BLM's would max out at 160 when it went into closed loop, open loop and WOT wouldn't matter because the O2 is ignored at that point.
Old Dec 4, 2007 | 06:20 PM
Car: 1992 Camaro RS
Engine: 305 TBI
thanks for the help, it must of been a weird fluke because it hasnt done it since i posted this. go figure! but i guess its a good thing. thanks again!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
formula_novice
Sep 5, 2015 03:58 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
